bendychicken »
https://forums.nicoclub.com/bendychicken-u8295.html
Wed Mar 23, 2005 6:31 am
2BN_S13, I did all of those things. If you read the original post, I did set it to TDC(BTW, there is no such thing as "compression" stroke until you you set the valve timming, Ex stroke and comp stroke are only differentiated by the position of the valves. And, since that position is set up by aligning the mating marks on the chains and sprockets that is irrelivent at this point in the proccess.) But, The valves hit the pistons when I turned it over by hand to test the timming(and to make sure I didn't end up bending my valves). And at that point I all ready had the lower front cover on, and the oil pan, and the crosmember, steering rack, etc etc. Plus, I believe that this is actually an exhaust cam that I'm using on the intake side. This would cause my timming to be off even though all of the mating marks were lined up correctly. The timming is not THAT far off because the engine does start up and run just fine. I just can't get the ignition timing just right. If the distributor is rotated all the way to the right(wich should make the timing light read about 20 deg BTDC or so) it reads 13 deg BTDC. My theory at the moment on the timing is that the cams timming with respect to each other is correct(How many teeth apart they are on the upper chain). And the upper timming chain is in correct time with the crank. But, the Idler sprocket in between the two is off. If the idler sprocket was off one tooth, but the upper chain was off one tooth in the opposite direction(or something to that effect) the valve timming would still be correct(or DAMN close), but that would still throw the distributor timming off by just a few degrees(In this case about 7 degrees retarded)..............................................................................................................................................................................................................................................................I think If I drive a wedge in the lower chain(to compress the chain tensioner) and remove the idler sprocket and jump it one tooth forward and reset the cams(by how many degrees the lobes should be at when at tdc compression
