F***ed up the wiring
Zero260
Car: 91 240sx coupe
yeah...so I hope I'm not the only one who has done this.
I was reading through the SR wiring Walkthroughs and thought I had it down. so I go look at my engine bay and find a plug, thats plugged into next to the fuse box and it looks like it's the one I need to do the swap. So, I cut it, and like 2 other plugs that were next to it, cause the website said, it's a couple of plugs behind the battery. when I finally got to the CA harness, only 2 wires matched the right color...hmm??? I go back into the engine bay and find 2 plugs to the left of the battery location that match exactly. so I cut those and wired them in.
the ones I orignially cut
the spot the came from
and where the correct ones came from
now my question is, has anyone else cut the 3 plugs off that mount right underneath the factory fure box? I haven't pulled the motor yet, so I don't know where they go to, I'm just wondering if I need to put them back, or if it's for something that I won't need wired up.thanks for advice in advance
Jiggyfry
IIRC I have one of those plugs to the right of the battery tray still unplugged. I have no idea whats its for and its not mentioned anywhere in the swap so I take it its not needed. I know the AC fan plug is near there.
ca18det240hatch
yah youre gonna have go to ahead and rewire those...mkay? Greeeaaat.
thats your transmission wiring, speed sensor, reverse sensor, 4th and 5th gear sensors, etc
wire it all back in , its important
johngriff
Car: 240sx
I spy, with my little eye.
A neutral switch/park/clutch. Wire that bad boy back up.
Is this an Auto car?
Zero260
Car: 91 240sx coupe
I acually have the lower ca harness also, and I was looking at that, and it has those plugs on it, so I can just use that...awesome
johngriff
Car: 240sx
The lower CA harness is no good.
I would prefer the KA harness over the CA.
If you are a jedi master, you could also splice in some vital accesories from that ca harness, but rarely does anyone.
float_6969
I've got a CA lower harness on my car and everything plugged right into my SOHC KA chassis harness.
DrIft Ready
Car: 1990 silvia built sr..
u can use a stock ka lower harness or a CA one everything pluges right in..the all u need to do is repin the red and gray plug and extend the o2 and mass plugs..that it..need any help with it just hit me up..can do it with the eyes closed
