Postby
LAQ »
https://forums.nicoclub.com/laq-u4740.htmlTue Mar 16, 2004 12:43 pm
got an oil change today and afterwards, check engine light came on and it wont go off.
EZ lube dudes obviously deny it's not their fault, but it never happended before. they think air flow meter went out, but why right after they worked on it?
im pissed. any suggestions?should i go to dealer and see whats up?
Postby
PalmerWMD »
https://forums.nicoclub.com/palmerwmd-u108.htmlTue Mar 16, 2004 12:43 pm
Askthem to describe to you how they changed the oil.
If they talk about changing from top ( which is not the approved way for this car) .Then you knows its their fault.Lots of stories of MAF problems from chaning oil from top w/ disconnecting MAF.
I always say at least 3 times to change from bottom if I ver go anywhere.
Postby
DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.htmlTue Mar 16, 2004 12:43 pm
Not if all they're going to do is read off the error code. You can do that in about 15 minutes. "Diagnostics" and "service" are pretty broad terms. Make sure you know what you're getting, in detail.
Postby
LAQ »
can u or are u able to check it out daedalus?them guys told me, 125 for diagnostics and they will try to reconnect it or something and it will be added to repair costs.
i'd really like to talk some shop with you as well if u r avail.
Postby
psychic_mechanic »
https://forums.nicoclub.com/psychic-mechanic-u12483.htmlTue Mar 16, 2004 12:43 pm
Yeah, they aren't kidding about wiggling the MAF. I checked my air filter when I first got the car, and made it run like crap. I had to unplug it again and clean all the contacts and reconnect it with dielectric silicone to waterproof it.
