well wouldn't it make sense that if you have cracked more than one manifold that it probably isn't your manifold that is the problem. It's most likely something causing it. And if you are so tired of cracking your manifold, just switch back to stock. Thats really your only other option.
If I were you I would buy another megan manifold, not those ssautochrome ebay manifolds. Then check your whole exhaust system for any kind of binding and weld a flex section in. Here is test pipe with a flex section in it if you dont want to do any welding.
http://www.projectnissan.com/s...=4290
And there is also a brace going from the downpipe to the transmission mount. Many people take it off....its there for a reason.
