extremm help needed
almin23
hi guys i have a 93 pathfinder and i was in the process of changing the ignition system.. the problem is it will not start nor crank after changing ignition cap and ignition rotor.. durign the process of changing the rotor i crank the engine to get the bolt toward the front so i can get it .. i put back everything and it will not crank.. nor start can someone help.. thanks...
NISTECH
dont know if you got this fixed yet. I suspect you have a factory alarm? If so under the dash there is 2 connectors that look identical. they have a group of black and white wires in 2 of the connectors but the connectors they are plugged into are more colorful. Plug the 2 more colorful wire connectors together and try to start it again. These connector would be by your right knee as if you were sitting in the drivers seat. They are right behind the lower dash panel about inline with the gas pedal. By doing this you are bypassing the factory alarm system.
