Extremely rich, need input please
pepegurr
Car: 89 coupe w/ rb20 swap - RIP but making a comeback
86 Porsche 944
92 FZR400 - Track Slut
95 240sx-se - Newest member of the family- DD
My wideband is showing that im running extremely rich alway through the rpm range. At idle im at 14-1 and under full throttle im completely maxing out the AEM UEGO it reads 10-1 , at cruise it reads between 12.5 and 14. Ive got the FPR set according to the fsm at 44psi no vacume. Should i try lowering the fuel pressure or should i look elsewhere for answers? Also how do you identify the injectors?
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Thats not extremely rich, thats more normal than anything. Lowering fuel pressure wouldn't really solve or help your situation. Do you have anything to tune with?If its the stock ECU on a stock motor with minor flow mods, that sounds about right, the ECU targets a richer fuel mixture under load to keep EGT's and A/F in a safe area of the fuel map.
neonbomb
I lowered my fuel pressure when I was running rich numbers and it helped just fine.
mattleegee
Car: s13+19 corolla
How low did you go?
pepegurr
86 Porsche 944
The only mods to the engine are 2.5 inch exaust and a r34 gtr fmic. I have a SAFC NEO but I have never tuned with one, so im kinda hesitant(sp?) to attempt to tune it myself.
dekansnowman
Car: 1995 240SX w/RB25
pepegurr wrote:My wideband is showing that im running extremely rich alway through the rpm range. At idle im at 14-1 and under full throttle im completely maxing out the AEM UEGO it reads 10-1 , at cruise it reads between 12.5 and 14. Ive got the FPR set according to the fsm at 44psi no vacume. Should i try lowering the fuel pressure or should i look elsewhere for answers? Also how do you identify the injectors?
What FPR are you using? I need to make sure I'm at the same PSI
