Car will start and idle without MAF, runs rich at idle around 10 AFR. As soon as I try to rev the engine it leans out so bad (off the chart) it cuts the engine off around 2000 RPM's. Car will not start with MAF plugged in, AFR off the chart lean.
Any Ideas?
CA18DET with blow through setup. Z32 Maf, 1G DSM 450cc injectors, t3 turbo, SAFC, AEM Wideband.
