srpowered240sx »
https://forums.nicoclub.com/srpowered240sx-u30143.html
Wed Oct 19, 2005 3:32 pm
background- red top sr20det in a 90 240sx. fmic, gt exhaust, blitz boost control, walboro fuel pump, stock everything else, has been running good for well over a year. here it goes...(6 months ago) kill first injector(stuck open, flood cylinder) on cyl no. 3(counting from front), replace injector, fixed problem(4 months ago) burn up coil and harness of cyl. 4 due to ground coming off firewall, replace coilpack harness and a coil, fixed problem, started race season, car ran great, mid 13s in quarter.(2 weeks ago) drop another injector, in cyl. 2 also stuck open. put in new injector, fixed problem, ran great again.(5 days ago) car would barely start after running great the day before. she would start but run on 3 cylinders, no. 2 injector was full open again. swap injectors to make sure problem follows the injector, but it doesnt this time. swap with another, same cyl is flooding and fouling the plug. now i start to scratch my head....so i call a buddy with an sr and we start to trouble shoot. i grab his ecu and plugged it in, and the car ran great. drove it around, ran tits again. so i plug mine in again to double check, and again, three cylinders, so im convinced. i order an ecu and overnight it, and plug it in (also to be sure i change spark plugs and reset battery) still three cylinders. WHAT!!??!!?!?!? same cylinder not firing.............im getting spark and fuel (seemingly too much) i need the SR20DET gods on this one. ive searched, and searched, and tried a lot of ideas found, but none have succeeded. any ideas would be appreciated, i need my car back, thank you in advance.
