^^^^ agreed
I started to get a slight gas smell and immediately thought injectors. Took the throttle cable cover off and looked at the front fuel lines at the fuel rail and both were a bit damp. Tightened up the clamps and viola, no more gas smell. That was nearly two years ago. I calculate my MPG every time I fill up, getting between 22 to 23+ each time. Got 24+ on the last tank ( was driving like an old lady while braking in my clutch ). Lower MPG can be a first sign that something isn't right or soon to be not right.
Things to note. If that N/A is a 2+2 you have a 19 gallon tank, not sure about the 2+0. When the needle on the gauge reaches E, you have 5 gallons left, or should if the gauge and sender are working correctly. The 'light' should come on after you driven it past E. It will go off again, after a bit more driving, then return. Odd to me, but verified.
