Extracting an exhaust manifold stud
Justin35ll
Car: s13 coupe sr20det
I was tightening down my exhaust manifold nuts and one of the studs snapped insided the head. Any help on removing it? I've never used an easy out bolt extractor. I've read that they are brittle though and have a tendency to break as well.Should I try the left handed drill bit first?
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Yes, try a left hand drill bit first.
snake240
Car: 92 hatch SR20DET
ive never had a problem with the extractors. they have always worked for me. good luck with that.
SpeedRacer1
Car: 1990 240SX, G35
I was impatient and got one out once by drilling three holes in a line into a stud stuck inside the head. Then I used a flathead screwdriver to get it out. But this took awhile. Try proper extractors first.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
That's a good I idea speed. I had my motor out and I still could not get it. I tried LH drill bits and easy-out's. I drilled / tapped the hole bigger and used a bigger bolt. It's the one at the bottom by the fire-wall so you can't see it anyway.
