High Plains Drifter »
https://forums.nicoclub.com/high-plains-drifter-u1612.html
Tue Sep 24, 2002 9:32 am
I am considering a similar swap, there seems to be more auto's around than manuals, so I figure to do a manual swap using the sr20's transmission. Here are my thoughts on the auto to manual swap: It should be fairly straightforward. Obvious things you will need are pedal assy's, clutch master cylinder and slave and lines, shifter, console pieces for the 5 speed, transmission crossmember.There should be no electronics to deal with going to the manual transmission except for wiring up the neutral safety start and backup lights both which are non-electronic. You should just need to disconnect the electronic wires from the auto and tape them off. My only real concern would be, is the driveshaft the same?I know with the 4th gen Maxima, several people have done a transmission swap and the automatic wiring just get taped off.
