topless@vabeach »
https://forums.nicoclub.com/topless-vabeach-u1506.html
Thu Apr 17, 2003 3:49 am
Go to radio shack and buy a 7$ multimeter. Set the scale to ohms and ohm out your leads. Should read nearly 0 ohms. Then hook one lead to the black wire, the other to your car chassis ( make sure no paint is between chassis and lead tip) check the reading. If it reads nearly 0 ohms then you are sure its ground. If not check the other wire
