extra credit problem..
drifter sx
Car: the usual
ok i need quick help. a friend and i were talkin about turboing a KA. i dont know much on the subject [just what i hear] but my prof over heard us. he says if i can get some SPECIFIC numbers together [horsepower, pressures, internal allowances etc] and make a good-enough problem out of it solving WHY EXACTLY the KA likes to blow [if not done right] i get an automatic B on an exam. thing is i dont have all the specifics or the time to read 348940574 threads on this subject.
my friend and i were thinking some sort of comparison between the SR and KA. like: the SR is stock turbo-ed so it obviously can handle the extra 'load' but the KA cant, this is why: [explanation here] FIND: what [HP, pressure numbers] WOULD make the KA stable....
anyone help me out?? :dunce thanks in advance...
s86d
Car: autocross, backroad racing, and working on 240's
I dont have numbers for you but SR and KA compression are different. also the strength of the KA ring lands on the piston are weak and thats what usually gives. as far as load tolerances for the ring lands... anyone??
fiznat
Car: Grown up :(
first of all, the KA does NOT "like to blow!" hahaha let's get that straight first!
what grade are you in, and what class is this for? It'd make a huge difference if it's for a sophamore year in highschool science project or if it's for physics in college..
next, you need to decide what you mean by "blow." There is alot that could happen to an engine... you could have rods break at high RPMs or bad piston-rod ratios, headgaskets burn out, valves bent from bad timing or detonation due to lack of fuel. you need to decide what "problem" you want to describe before you dive in.
I really think the last thing - preventing detonation - might be the easiest. You can describe flow rates of the engine and fuel demands at various presures, then show what detonation is and all that. Theres a lot of physics in that or you could describe it simply... depends on what you wanna do.
drifter sx
Car: the usual
aright pretty usefull info... im gonna work out a few more details with my friend and get it back to ya...
PS this is for an upper level college thermodynamics class ;) so feel free to use big words
Duckmeister
Car: 2004 Sentra 1.8S
This might help a bit.
There is a Car Magazine (dont know the name) that is pretty common i suppose that has a section on this guy who installed GReddy's new Turbo kit on his KA.
The magazine was car something..next time i'm at the bookstore ill get the name for it.
gl man
