S13FASTBACKSR »
https://forums.nicoclub.com/s13fastbacksr-u34823.html
Thu Apr 19, 2007 4:52 am
an external wastegate does not mean you can only one run exact psi of boost such as 10psi. an external wastegate does not mean you cannot use a boost controller or does not mean you cannot up the boost..the spring size such as a 10lb spring in your case means that you cannot go lower than 10lbs of boost..that is your set gate pressure..you can get a boost controller and up the boost to 11,12,13 or any boost you want you just cannot go lower than your spring pressure of 10psi
