External Wastegate question
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
Do external wastegate's need to be dumped to atmosphere to work properly..??
Can dumping the wastegate back to the downpipe cause boost creep..??
ThanksRobert
TrunkMonkey
Car: 2000 Lincoln Navigator
rn240sx wrote:Do external wastegate's need to be dumped to atmosphere to work properly..??
no.
if it's rerouted into the downpipe like yours, it could be a prime suspect. i saw your setup on your cardomain site...that's damn near a 90 degree angle.
-demetrius
rn240sx
09 Ninja 650R
06 Suzuki S40
Where do u see a 90 degree angle in that dump return pipe..??The dump return pipe leaves the wastegate with ZERO angles, its a straight dead on shot to the downpipe..!!Unless ur talking where the actual gas pressure meets at the downpipe, then yes, once the gas pressure hits the downpipe, it then has to make a 90 degree turn down..!! But leaving the wasetgate, its a direct straight shot..!!
TrunkMonkey
rn240sx wrote:Unless ur talking where the actual gas pressure meets at the downpipe, then yes, once the gas pressure hits the downpipe, it then has to make a 90 degree turn down..!!
i will say no more.
-demetrius
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
thats funny you say that because i predicted it in the other thread. but then again i dont know what im talking about.
