s13redmon wrote:...Plus I've heard that externals work a lot better for higher boost, and I'm planning on running around 16-18 psi.
BLECH, not true! I have a friend that runs 20psi on an internal waste gate turbo. Works just fine. Here is when you need an external wastegate;
You have mis-matched turbo that has a small turbine side, and a big compressor side, as the turbo spools up, it settles at your wastegate pressure of 18psi. But as you continue to rev, the boost creeps UP to 25psi by redline. Your internal wastegate is too small to bypass the extra exhaust gasses, so the turbo spools faster once the internal wastegate opens all the way. So if you want to run 18psi on this setup, you need an external wastegate.
Now here is another scenario. You have the same, mis-matched turbo, only you want to run 27psi on it. The turbo will spool up, hit 27psi, but falls down to 23psi by redline. This can be caused by 2 different problems. The first is that you're over-revving the turbo, and it can't move enough air to make 27psi of boost pressure at redline. The second is that the spring in the wastegate is too weak to hold 27psi. If the turbo is big enough to make the boost, but your not keeping it, then you can still use an internal wastegate, you just need a stronger spring it in.
That friend I mentioned that was running 20psi on an internal wastegate was talking to me when he first installed it and complaining about the performance. I asked what the symptoms were, and he said that the turbo would spool up to the 15psi that the wastegate spring was set for, but by the time he got to redline, it was creeping to 20psi. I asked if he was leaning out or detonating at 20 psi, and he said he wasn't. I told him to buy a boost controller and run 20psi, then he wouldn't get boost creep anymore.
Same thing happened to me when I first had my T28 on my CA. I was trying to run low boost on it because I was waiting for E85 to be available in my area. But the combination of my high compression, ignition retard to fight detonation, and excess fuel to fight detonation, left so much energy in the exhaust that I'd hit my 5psi wastegate pressure, but at about 5K, it would start to creep, and by redline, I was up to 10psi. I had to take my redline down to 6K so that it wouldn't detonate until I could get to some E85.
