External Trans Filter
MCovington
Car: 1995 Q45
Is there a factory external trans filter on a 95 G50. If so where is it located. Need to drop the drop the trans pan and clean the inetrnal filter soon.
Thanks for any help
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Yeah theres an external filter, its located near the battery, you can see it if you look by the battery...
It may be easier to convert it to an aftermarket filter setup that uses screw on oil filters, especially long term. Summit racing sells them.
rhinoone
What year did Infiniti start using that filter?
elwesso
2007 BMW M Coupe
94 but some 90-93s have the external filter. If the trans on a 90-93 (VERY COMMON on 90-92s) was ever replaced under warranty they got an external filter, however the 94 external filter is slightly different because it has a 2 in 1 out setup vs a simple 1in 1out on the earlier style.
qship96
Car: 1996 Infiniti Q45
elwesso wrote:94 but some 90-93s have the external filter. If the trans on a 90-93 (VERY COMMON on 90-92s) was ever replaced under warranty they got an external filter, however the 94 external filter is slightly different because it has a 2 in 1 out setup vs a simple 1in 1out on the earlier style.
actually,the 94-96q external filter has 1 input and the OUTPUT is split into 2 to feed the two coolers in radiator
elwesso
2007 BMW M Coupe
Ok thanks for clarifying.. I just ripped mine out!!
So is the proper circulation cycle is it comes from the 1 port tube, goes to the trans filter, then splits into 2 to each side cooler, then back to the 2 port tube back to the trans..... Good clarification.
T45
Car: King Kong powered Z32
My 92 also had the little finned heat sink on the trans line under the trans along with the ext. filter.
So I can assume that the trans was replaced at least once under warranty by infiniti?
Not that it matters. I need to get rid of it anyways, it's just taking up room. Anyone need a trans? It's in VA. No shipping.
MCovington
Car: 1995 Q45
Is the factory trans filter just a replacable cartradge or what?
Thanks
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
its a kit. comes with the mounting bracket to the frame and 2 longish hoses attached. does not have the shorty hose to the pass side radiator tank.
T45
It's a spin on filter just like an oil filter. Actually, it is an oil filter.
qship96
it is NOT a spin-on filter,the assembly is replaced as a sealed unit including filter element and casing/hose barbs and hoses-no replacable filter element,as the case is welded
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
It's like a big fuel filter sorta isn't it?
qship96
similar in design,as it is a welded case containing a internal non replacable element,but shaped like a oil filter!
AlabamaDan
1998 Infiniti QX4
So should it be replaced at any interval? Mine's probably OE.
elwesso
2007 BMW M Coupe
I would personally replace it with a filter with a screw on thing, an aftermarket one from summit or something like that. Should be the same price or cheaper than OEM and will allow you to conveniently replace your filter whenever you want.
qship96
I replaced mine somewhere around 120-140k if memory is correct-I think every 100k should be sufficient if you are replacing the atf at frequent intervals,say every 25-30k.I vote for just ordering stock kit from joe instead of trying to fabricate a universal kit with replacable element as the space is tight where it is located and the kit is a quick drop in process that infrequently needs attention and is affordable=around 70-80 dollars=much,much more important changing this filter than the coarse in pan screen strainer that everyone on this board worrys over as this is THE REAL FILTER,with a fine filtering element similar to an oil filter
I bet I am one of less than 5 people on this board to have EVER replaced this filter!!!!
MCovington
Car: 1995 Q45
Thanks for the information. Just looking at the filter I couldn't tell if it just screwed off like a oil filter. Anyway I guess this will be on my replacement list soon.
T45
I retract my previous statement and choose someone elses instead. lol Sorry, I didn't look at it THAT close.
Open. Insert. Open. Insert.
Hey my old lady is right! I'm getting pretty good at this!
