Hey Jesda, thanks for the post. Any tips/suggestions/post with instructions on how to do this on a 99 Q? All I see are posts for G50s.Jesda wrote:Just get a small one. I got mine for $30 at a car parts store and had it installed between the radiator and fan.
Y33s dont need them as much as G50s, and while youre in a colder climate, you may have a situation where you've got four people and a trunk full of luggage going up a hill in July. Plus, what if you drive south?
Peace of mind.
I don't think that the expense and time would be worth it on a 97+ in Minnesota. It's very possible that a cooler would not allow your fluid to heat up enough in 0 degree weather and fluid thats boiling or freezing is bad. If you did install one I might add a shut off valve so that it wouldn't be used in the winter.greenwar wrote:
Other Q owners in cold weathers... help me out with some posts.
I've felt pretty confidant about not bothering with a transmission cooler in this climate - until this summer. I took a trip to the Minneapolis airport to pick up some folks - 80 mph, 93 degrees - stopped at a rest stop ... and left an ounce or two of transmission fluid on the ground when I started her back up. I never found out exactly what happened (shame on me), but it made me nervous. I got to thinking about the hot soak after shutting it off, from cruising at that speed in that heat. I think the fluid MUST have bubbled out somehow - no leaks, nothing since. If so, it got pretty damned hot in there.greenwar wrote:Other Q owners in cold weathers... help me out with some posts.
And my 2 1995 G50 also. The pressure is not very much (under 100psi), so a good fitting and hoses that don't get routed onto metal or stretched will work fine if the fittings are tight. Why one always inspects the car on the lift when the under engine tray is off while the oil is changed.greenwar wrote:Brian, you think the B&M fittings are adequate to prevent leaks? I know you are trusting their fitting for your 2K Q45.
I am loving the silky smooth ride of the Q. I thought camry's are smooth riding!!
Yes, but you can check with your local U-Haul place to see how they would do it.03XTERRA wrote:Maxnix,Do you know anything about putting on an external transmission cooler to a Xterra? I'm towing a 4 cy Tacoma behind my RWD, V6 Xterra 2,200 miles. Any suggestions? Do you by pass the current radiator and attach the in/out lines to the external cooler only?Thanks
