Cjmartz2k wrote:Not needed at all for your application. The aussie guys (mostly sydneykid and his groupies) push the hell out of the "oil stuck in the head" problem. Thing is, it's not a problem. It *can* be helpful to put the "drain" in the back of the head in high boost/high RPM/high hp applications because there is so much blow by going up thru the oil passages down from the head, it can blow the oil back up into the head. The additional "drain" is simply another place for the blow by gasses to go, it's not really a drain, and not needed in 99% of RB's.
They argue the s*** out of the mod to justify to themselves how much money the spent on a not needed mod.
Agreed. I bought into the "oil drain" mod back in the day. However after aging, and learning more about this motor its simply not an "oil drain back". The giant holes in the back of the head are the oil drains, and they are large factory. This acts like Chris said as more of a pressure evac from the head than anything.gawdzilla wrote:
not running one . arguably overhyped. however, i did notice a BIGGGG difference with blowby when i put the mines baffle plates in the valve covers, which does something similar to the drain but requires less work. sustained high rpms with hot oil will push a decent amount through the vents, but the mines baffles definitely put a stop to it.
+1Cjmartz2k wrote:Not needed at all for your application. The aussie guys (mostly sydneykid and his groupies) push the hell out of the "oil stuck in the head" problem. Thing is, it's not a problem. It *can* be helpful to put the "drain" in the back of the head in high boost/high RPM/high hp applications because there is so much blow by going up thru the oil passages down from the head, it can blow the oil back up into the head. The additional "drain" is simply another place for the blow by gasses to go, it's not really a drain, and not needed in 99% of RB's.
i assume you're talking about drag track here? just top off with an extra 3/4 qt every time you go to the track and you should be goodralphsdiorama wrote:If I am going for a mostly street car (track time every other month) with around 550whp at the most with an N1 oil pump (Boost @ 20psi). Should I just do a 1.5mm restrictor and mines baffle plates. I'm guessing using the drain as a pressure release would not be very beneficial unless I was running a lot more power and boost. Thanks
