Amen to that point.
DFW2011M56S wrote: ↑Wed Apr 15, 2020 8:58 pmMine never had a power problem once it actually reacted to the throttle. That being said like clock work when the oil temp would hit 210°F it would limp the throttle and have ZERO power under 20-30 MPH. Then it would wake up and run like a bat out of hell. You could not even free rev it in neutral. You could hit the throttle to the floor and it would lay over and then respond 2-3 seconds later. Water temp could be any value, air temp could be just about any value, but as soon as it hit 210 on the oil it would fall on its face. My briggs and stratton lawn mower would have beat it across an intersection while towing the car. It was literally that bad no exaggeration. Put a massive oil cooler with the biggest Setrab core I could find and never had that issue again. I had the Nismo 300ZX 144°F thermostat and the fans set for 170°F turn on. Water never ran over 178°F.
Once you have HPS intake hoses, a dual 2.5" exhaust and tuning the air intake ducting IS a noticeable restriction. Nearly 20 hp @ 7,000 rpm on my car. I ended up installing it back and swiss cheesing my air boxes. I had 428 HP and 434 TQ when my car was last pulled on the dyno. Ran a 12.2 @ 112 in 90°F weather.
Yoda's Master wrote: ↑Thu Apr 16, 2020 1:53 pmThis was discussed last aug and mikedamageinc doesn't understand that nissan cars will likely go into limp mode somewhere above 220. Doesn't matter if he believes the oil can handle higher if our cars will put you in limp mode.
Yoda's Master wrote: ↑Thu Apr 16, 2020 2:05 pmlooks like you quoted, while i was editing and adding onto my post. like I said, go read up on the 370z forums, not on nicoclub. You'll see lots of limp mode posts with high temps
maybe nissan raised the limts on newer model years. There's a lot more posts than just that one you found from owners with earlier model years. Either way it's your choice. My experiences are positive post oil cooler installation since I have the 09 model.ken in az wrote: ↑Thu Apr 16, 2020 2:39 pmDid a little searching, and this is coming from someone on the Z forums with almost 7000posts....
"Stage one limp mode isn't until 280F, stage two limp mode is 300F but probably pretty difficult to reach when already restricted."
Which makes a little bit more sense than 220F degrees
Not saying you are wrong Yoda, but I can't find anything that says 220deg F causes Limp Mode. Seems to be much higher in the temps that cause it."So, the big issue i had is this... About 10 mins into my first run, I noticed that the oil temperature gauge was pretty much burried at 300f... As soon as that happened, my rev limiter moved from 7500 to 6000... Every time I'd accelerate through a gear it would prematurely cut the throttle at 6000rpm... Was extremely frustrating as it seemed to cut in at all the wrong times and slowed me down overall by at least 10%
It happened in all four of my runs, usually about 10 mins in.
I can only imagine this is going to get worse as I move to stickier tires and tweak the motor.
It gets worse... After the fourth and final run, it dropped the rev limiter from 6000 to 3500, just as I was pulling off the track. I decided to keep the car running after the session to let the engine cool. Tried to drive it home, and every time I accelerated through a gear it just cut the engine at 3500, sending it back down to 2500... I had to shift gears real fast... luckily 6th gear is good for 80mph at 3000rpm, so I made it home. Also, it turned out that after I shut off the car and restarted, the computer had reset and all was back to normal."
Uprev did not help with the shifting. If anything adding torque makes the 7spd stack shift and lockup the converter even sooner.ken in az wrote: ↑Wed Apr 15, 2020 9:21 pmDang, that is moving! I ordered a 30row cooler, lines, and a thermostatic oil filter adapter to install. You don't happen to have any pics of how you installed and ran your lines for the cooler?
Also, how'd your trans hold up? Did the Uprev tune help with shifting?
Too bad HPS doesn't make their hoses anymore. I have something coming in the mail this weekend to try and make something work equivalent to their hoses. Can you say "eBay special? Haha.
I thought about getting the 150deg tstat but was concerned if that would be too cool messing up the cold start closed loop fuel tables. I'll probably get the 170° F thermostat for now and adjust the fans to kick on earlier once I see the coolant temps start being the problem.
I'd like to thank you for your post, now I'm gonna be like a stalker and go read all your posts haha
