deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sat Nov 04, 2006 3:09 pm
I have devised various methods for both alternate injection (water, alcohol, nitrous etc.) and staged sequential injection (gas, maybe alchol) using the ka24e ecu.
Both methods mentioned operate in "dual table" (2x 16x16) table switching fashion, allowing dedicated fuel/ign tables to each "state" (off/on alternate injection), with configurable switching characteristics based on any sensor that the ECU uses, as well as additional sensor such as external EGT or MAP sensor.
The difference in the two methods mentioned is one simply provides a switching output to control, say, a water injection pump for continuous "on" operation over the set points. The other, staged injection method, allows a minimum of 4 extra injectors to be installed (piggybacked off first 4). The 12v + power source to these additional injectors is also controlled by the ecu, rather than directly connected to the battery. Controlling the 12v+ for the secondary set, the ecu can turn the set on/off. The same pulsewidth is always provided to all injectors, but here is the beauty of it, in combination with a dual table ign and fuel table correction, the ecu also switches to a completely different K (base fuel factor) during the switch over. This allows you to trim this base fuel factor down so that the set of 8 injectors provides a more appropriate pulsewidth that can be tuned appropriately as desired on the second table.
This is all fully contained within the original ecu hardware and I have it working with a huge code re-work. The code (staged injection type) will be freely available with more details in a few months.
The first method mentioned above is already available, the code is called EC3 (currently EC3b) and has a couple other features as well.
