I was going to put one on my G50 but as much as I love spin on filters, I don't want to waste all that expensive fluid... I guess what I need to know is how often you change those filters and if it would be worth the price of the extra quart of syn fluid every time you do.Skibane wrote:I ended up mounting mine on the driver's side front bumper bracket - Makes it easy to remove without making a mess.
I took some pressure measurements (link to thread here) - the spin-on filter added no extra back-pressure. At least on the Y33, the original in-tank cooler by itself is more restrictive than an external cooler and spin-on filter combined.
I would think it would be worth it. Mainly because you dont have to drop the pan. Well, You do to drain the fluid. I would change the filter every 12,000 miles then add a extra quart. then after 30,000 miles, drop the pan and replace all of the fluid. Might even be worth installing some kind of drain plug on the pan.lasoyafan wrote:
