Extended Studs?
1sikS13
Car: 1992 S13 240sx
Anyone got a parts# for arp or where i can longer studs in the rear for my 5 lug hubs i gots a 15mm spacer i wanna throw back there
E7-S14
Car: ess 14 foo!
http://www.frsport.com/Peak-Pe....html
does it have to be ARP?
check FRsport.they have a few diff. brands of extended studs.thats just one brand in the link.
1sikS13
Car: 1992 S13 240sx
no i just figured they would be best...and the fact that the rear studs are slightly different then the front made me think that arp would be the only company to manufacture quality studs.
gumby74
Actually on an S13 the front and rear are the same in regards to knurl size which is 13mm I believe.The S14 uses 14.3mm fronts and 13mm rears.Just throwing that out there.
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
1sikS13 wrote:Anyone got a parts# for arp or where i can longer studs in the rear for my 5 lug hubs i gots a 15mm spacer i wanna throw back there
http://www.arp-bolts.com/Catalog/Catalog.html
adrianfromthecastle
Car: 1992 Nissan 240sx
gumby74 wrote:Actually on an S13 the front and rear are the same in regards to knurl size which is 13mm I believe.The S14 uses 14.3mm fronts and 13mm rears.Just throwing that out there.
I dont know if that's true or now (spec wise)...
but I know for a fact that they don't fit the same. Rears are a bit smaller (maybe by half a mm or so)... I have peak performance studs, they fit like butter up front, but the rears I had to do waaay more work....
ArcherV20
Car: 1995 240SX
At what point do you need to be looking into extended studs? Sorry to threadjack, I figured this was a decent enough place to ask.
adrianfromthecastle
ArcherV20 wrote:At what point do you need to be looking into extended studs? Sorry to threadjack, I figured this was a decent enough place to ask.
10mm spacers or more...
but imo... I wouldnt use 15mm spacers on ext studs (or anything thicker)... at that point, I'd just get bolt on spacers.
gumby74
Well I just did a quick search and Nismo wheel studs for an S13 are the same pn front and rear as well as S14 rear and Z32 n/a rear.The fronts for the S14 and Z32 are the larger knurl size which I rounded to 14mm.just sayin'...
adrianfromthecastle
