extended studs + ichiba????
TheS13Guy
Car: 89' 240sx
I know that ichiba sells 5 lug hubs with extended studs but does anyone know if you can press in your own extended studs into their hubs??? The reason I ask is because I want to go with Nismo or ARP extended studs. Thanks in advance.
simmode1
Car: Red '95 S14
TheS13Guy wrote:I know that ichiba sells 5 lug hubs with extended studs but does anyone know if you can press in your own extended studs into their hubs??? The reason I ask is because I want to go with Nismo or ARP extended studs. Thanks in advance.
I don't have these parts, but every post I've read on the topic states that replacing the Ichiba studs with Nismo or ARP is a neccessity if you value your life. So, the answer to your question seems to be 'yes'.
TheS13Guy
Car: 89' 240sx
Ok man thanks. I was going to go with a set of used s14 hubs but cant find any. Plus I heard the ichiba hubs do just fine for track use.
