Correct.lofapoo wrote:So basically, when I'm in the freeway in third going at 4k, and I flip on the O/D, it will put itself into fourth gear, thus making it go at a lower RPM?
Only as useless as 5th gear is while driving in 3rd on a 5-speed. If you're REALLY pegging redline in 2nd gear, the transmission might just jump to overdrive if you get off the gas real quick.lofapoo wrote:So unless I make it to third gear, O/D would be rendered useless, correct?
Yep, it'll stay in 3rd.2BN_S13 wrote:You are telling me that 4th will not get used at all unless you press the button, huh?
