explain how to measure tps adjustment??
Unstock240
Car: 89 240sx se
My car had no powerband, so I swapped my tps and it is much better, but now i think it needs adjusted. I don't understand how to measure the .45-.55 volts? Do I measure it plugged in or what? also note I put on an auto tps with 2 plugs so which plug and where? Do I need to prick the wires?
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
If you have a scan tool the voltage should read about 0.3 to 0.7volts at closed throttle and about 4.0 at wide open throttle.
drivinsidewayz86
Car: 89 240sx , 90 240sx , 90 240sx , 98 240sx , 88 hardbody 4wd,02 sentra se-r spec-v,95 240sx
you can use a multimeter and test the signal wire while opening and closing the throttle as well
vancouverbc
Car: 1991 240sx
Unstock240 wrote:My car had no powerband, so I swapped my tps and it is much better, but now i think it needs adjusted. I don't understand how to measure the .45-.55 volts? Do I measure it plugged in or what? also note I put on an auto tps with 2 plugs so which plug and where? Do I need to prick the wires?
\plugged in . probes in back of connector.
