C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon Jan 19, 2004 8:56 pm
I assume you are talking about spark plugs.
Higher heat ranges retain more heat at the electrodes. Too much is bad as it will promote detonation. Colder heat ranges then run cooler, which is better for higher compression or NOS/Boosted motors, but if too cold, will have a hard time burning off carbon deposits off the electrode.
