experts advice on electronic fan
drftsx
Car: 90 240sx(sr)
im wondering if i can run the stock Ka electronic fan thats in front. since i took out the ac and everything my radiator will the in front of everything else. do you guys think this is safe or will i still need bigger fans. by the way im runing on stock sr radiator. thnx
180fan
Car: 89 fastback
bigger fans. then again...winter is coming back around and it gets pretty cold inland at night but still gets pretty warm during the day...I'd probably get a 12" fan for the primary fan.
drftsx
Car: 90 240sx(sr)
do you think i can run it in ront of the radiator, or would it be wise to run it in the baack??
180fan
Car: 89 fastback
probably if it were pulling air in would be better but even then, i'd recommend running a real fan vs that little aux fan.
Vr6WantSr20det
are u talking about the s13 or s14 electric a/c fan? I'm using the s14 low/high speed fan on my s13 sr20det but i have a koyo aluminum radiator and have had no problems so far in nyc summer or here in florida. It works through my blitz lm fmic and the a/c condensor then the radiator and keeps the car cool. But i will definately be upgrading to either the stock clutch fan or altima fans since i'm putting on a bigger turbo soon.
drftsx
Car: 90 240sx(sr)
do you guys think i can run a 14" fan in the front of the radiator? since im going to do a V-mount ic? or would it be a problem. also, do you guys think i can wire the fan to be ablw to run with the Ac fan??
Gramentz
Car: s14
I've got two 12" electric fans with a koyo alum. radiator. Never comes close to overheating in FL and the temp drops dramatically when cruising. Use the stock clutch fan versus the a/c condensor fan... if you're not going electric.
