FandGMotorsports »
https://forums.nicoclub.com/fandgmotorsports-u66150.html
Thu May 24, 2007 2:24 pm
i did some readin in this forum a few weeks and was inspired to find an affordable solution to the vh internals. the crankshft is alreay top-notch and the block has all the nessarcy reenforcement i found that people wanted to use a 400 small block rod with a 305 piston the rods are roughly $619 bucks from summit for an eagle h-beam, the pistons are super common but afforable forged 305 pistons only come as a flat-top 4 valve releif, this is going to give a high compression ratio due to the extra bore and having similar valve releif sizes, also i had a block sonic checked and found that a .075 overbore isn't going to work (safley) (by the way the .075 would put the block in the realm of a stock 305 piston) also the rod discussed in the previous vh forum is too short and the piston won't clear the counter weight, at least without some extra machining, plus the 5.565 rod length would decrease the rod ratio. i was inspired by the information found in this forum to start in with more research. i found a good custom piston supplier through my speed shop i run but wants 80 pieces (10 sets) to make the order. i already bought one set but they cost a fortune. i know this motor has huge potential but need to lose to the cast pistons to get the extra power. the only obstical that ive found is grinding the rod journal down .060 to fit the chevy rod and having the rods slightly narrowed. the pitons have the light .043 ring pack and use the easily obtainable chevy pin, you could even use the H-series bearing for extra abuse. what does everone think?ent...this is what i found..
