xung »
https://forums.nicoclub.com/xung-u21872.html
Fri May 27, 2005 9:15 pm
Has anyone else tried this oil additive called "Engine Restorer"? They sell it at Walmart, comes in a can about the size of a can of pop, bluish stuff. The claim is that it restores compression, gas mileage, prolongs engine life . . . . . My understanding is that it thickens the oil so there is less pressure leakage around the rings.
So I tried it for a week and then took compression readings before and after.Before they were:149134150151
now they're:156141156156
I was hoping for it to even out the compression a little bit more instead of just increasing it across all four. I don't think I notice a power difference while driving and I haven't fill up again to know if there are improvements in gas mileage.
I'm wondering if there are any negative drawbacks to continuing to use this stuff or if others have past experiences with this. Would I be able to just substitute heavier oils like 20w-50 instead of buying this stuff? Has anyone notice this much difference in compression going from 5w-30 to 20w-50?
