Before I get too far into this, I'll start by getting straight to the point. If you have any experience simulating the narrowband signal from a wideband sensor to the factory ECU, I would appreciate a few minutes of your time. If not, then I guess you can speculate and enjoy the conversations. I haven't been able to find a lot of information on this sort of thing here. [It doesn't help that the search isn't working right now for some reason.]
I have a thread over in the SR forums from earlier when I was just looking for clarification into how to wire this thing up.
want-to-simulate-narrow-band-t578149.html
So that, along with some conversations on facebook, has spawned further questions and is leading me to take a closer look at this setup.
So here is where I'm at currently: First things first, my factory narrowband is essentially junk. Somewhere along the line, all the threads have been trashed so I can't install this thing back in the factory location without buying a new one. When I was doing some research on widebands, I found out that most sensors can simulate the narrowband signal for a factory ECU. Why bother with a factory sensor then, right?
Now I have the wideband sensor installed in the O2 housing. I have figured out where to wire the narrowband signal to the ECU. I've also come to the realization that I'm going to need to put the factory sensor somewhere as the ECU sees the voltage or current or both (haven't figured that out yet) coming off the heater from the sensor. In the future, I'd like to upgrade to a Nistune ECU and they've got some different wideband capabilities. So right now I'm thinking I'll leave the wideband in the factory location and stuff the narrowband in the downpipe to be removed later when I have more tuning capabilities. I don't mind if it leaks a little bit and I don't want to have to re-loom my whole harness that I'm 90% done working on to put the factory O2 wires back in it; but if that's what it has to come to, I'll do it.
I also keep hearing horror stories from people with experience that the sensors just don't last very long. Stories on the intrawebnets vary drastically from 200 hours to 50k miles as expected lifespans for these sensors. I can't quite figure this out and I'm going to do more research. What's the point of having a gauge permanently installed in a car when you only use the gauge for tuning occasionally?
