jetdriver »
https://forums.nicoclub.com/jetdriver-u22064.html
Tue Jan 10, 2012 2:18 pm
I changed my throttle body from a rb25 to an I30 so I could have cruise control. The tps wiring is reversed on these because the sensor is on opposite sides of the TB. The first time I ran the car with the new TB and wrong wiring, it ran the same as before! When I checked to see if the wiring was reversed, I was sure it did not need to be changed because the car ran so well. All this to say I don't think a bad tps will cause as big a problem as you are having.
