Expected power output?
Maverick05x
Hey guys, here is a question for those of you who are engine build savvy. Below you will find a current build sheet for the motor I am currently running. Before I deployed the car was tuned and dyno'd at 385 and change WHP on 18lb of boost on pump gas (93 octane). Considering the build it seemed a bit shy of where I was projecting the car to be, which was into the 400's. Now on C16 and 23lbs of boost the car made 435whp. When I get home in OCT I am planning to install an AEM methanol injection kit which will be at a constant flow, swapping the turbo housing and going with an external waste gate I will have fabbed into the current manifold or turbo elbow. So my question is what kind of numbers do you think I should be looking at here reasonably running at 21-23lbs on the methanol? I see stroked 2.2 SRs pushing 450 with a GT28 on a stock top end, I dont see how that extra .2 liters would not be made up for by a built head and a larger turbo. Is 450+ possible on my current set up?
SR20DET Black Top
Brian Crower Rods
JE Forged Pistons
ARP Head studs
Main rod bearings and stock crank bearings (blue printed)
HKS Head gasket
Stage 2 Brian Crower Cams 264/264
Brian Crower Springs and retainers
Tomei solid lifters and rocker stoppers
HKS Bottom mount tubular manifold
Greedy FPR
1000CC HKS injectors
Greddy Fuel Rail
Apex’i Cat back exhaust with sp2 muffler
AEM GM Map sensor bar
Intercooler 26x12x3
KOYO Radiator
AEM Methanol Injection Kit (Not yet installed)
Greddy Intake Manifold
Greddy Boost Controller
Greddy Turbo Timer
B&M Short shifter
Doug Dapree sub frame spacer
Twin Whalbro fuel pumps (In tank and in line)
Garrett 3071R Turbo
Tial 44mm external Waste Gate (Not yet installed)
Cryo treated transmission
ORC 709 Twin Plate Clutch
J30 rear end
