Aus94Q45 »
https://forums.nicoclub.com/aus94q45-u136.html
Thu Nov 03, 2005 11:16 am
Guys I am no superman, but I did mine and they were a piece of cake. Now that said. if a mechanic would install them for $100-$130 as stated above, I would go that route, just to avoid the hassle. But I purchased a decent spring compressor set and easily changed these out. Take off the wheel and jack it up to where the strut is fully extended. MIne came off and the new ones went on with little effort and no "muscle" -- just had to align and gentley push into place. By the time I got to the rears, it took longer to removed the trunk panel and wheels than to take out and reinstall the new shocks. Do get spring compressors with lock pins; Do pay attention to how the spring lines up in the mounts; Do be careful with the spring assemblies (ie. don't put your face in front of the top bolt as you remove it just in case). But as others have stated here, it is an easy DIY job on the regular Q's.
