Exhaust (yes I searched)
naladude911
Car: 2001 Infiniti QX4
My stock exhaust is shot. The pipes are all rusted through, and it sounds like a buzzing bee. That, and I have horrible gas millage. I have searched NICO to find that you all recommend magnaflow mufflers with straight pipes. Can someone please link to me the exact muffler I need off their website (i want single out). thanks
Pwnin O'Brien
Technically nothing made by Magnaflow will bolt right up to your current factory exhaust. The smallest inlet size you can get as a dual-in/single-out is 2" inlet/2.5" outlet. The factory pipe is 1.65". So regardless of what muffler you get, you will need to have the factory pipe expanded or replaced to the larger size (depending on the inlet size of the muffler you choose).
Here's the link for the dual 2" inlet/single 2.5" outlet muffler by Magnaflow (Keep in mind that all Magnaflow mufflers are reversible)... http://www.magnaflow.com/02pro...=7996
Pwnin O'Brien
Also, a search would have yielded the following thread (which contains all information on the R50 exhaust you would need to know)... zerothread?id=448373
oasisx
Car: 2001.5 Pathfinder
here you go:
http://www.autopartswarehouse.....html
not sure if thats exactly what u need, but its what i was looking into for my new exhaust parts. look around on the site, you'll find what u need.
oasisx
if you buy from there, check this site out before you payhttp://www.retailmenot.com/vie...e.com
W O T
Car: 2001 Infiniti Qx4
Id help but... Ive seen your d!ck answers to people
naladude911
wow these are great, I'll go to Meinkee today
naladude911
I went to Meinkee, they said $1000. LMAO
car nut
Car: GT500.
Learn to weld. Makes everything in life easier.
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
naladude911 wrote:I went to Meinkee, they said $1000. LMAO
Welcome to the real world. I'm student to and I feel the pain.
Dyjacu
Buy the muffler, and take it up to Gallon Measure in Buchanan, they will probably install for $200
naladude911
Attention R50 owners. Help me convince my parents to get a magnaflow system instead of replacing with the OEM. My parents think the OEM will be better.
longhornsqx4
Car: 2001 Nissan Pathfinder 3.5L VQ35DE
OEM will be better
Empty V
1982 Chevy Corvette C3 Shark
naladude911 wrote:Attention R50 owners. Help me convince my parents to get a magnaflow system instead of replacing with the OEM. My parents think the OEM will be better.
Attention Nala, be a man, get a job and pay for it yourself!
Billy
Pwnin O'Brien
longhornsqx4 wrote:OEM will be better
I respectfully disagree. The OEM exhaust is designed for one thing, noise reduction. The mufflers are extremely restrictive and choke the engine. There is an enormous buildup of back pressure due to the main muffler and EGV's are very low with a factory system. On top of that, the factory system is comprised of steel (I don't even think they used alumunized steel) which will rust immediately and will cause failure within a few years. Yes, with an aftermarket exhaust you will get more exhaust noise, but the lifetime warranty alone is worth it.
naladude911
Will this muffler work? I convinced my parentshttp://www.magnaflow.com/02pro...=8065
Pwnin O'Brien
naladude911 wrote:Will this muffler work? I convinced my parentshttp://www.magnaflow.com/02pro...=8065
Yes, that muffler will work. The only caveat, however, is that you must either replace all pre-muffler piping (the factory pipe between the resonators and the main muffler) to match the new 2.25" muffler inlet or you will need to have the factory pipe expanded at the end to fit the new muffler.
This muffler isn't just plug'n'play, you can't just weld it in since the pipe diameters are completely different.
naladude911
Is this the muffler? Im getting it done really soon. Stainless pipes.http://www.magnaflow.com/02pro...=8021
Pwnin O'Brien
naladude911 wrote:Is this the muffler? Im getting it done really soon. Stainless pipes.http://www.magnaflow.com/02pro...=8021
t_b0ne3
Car: 2002 Infinti QX4 4wd My first Nissan was a 1985 720 4wd P/U. My other ride is a 2005 FXDWGI
Billy
LOL There ya go Empty V right to the point and more pointedly right to the CHIN!!
