Ubernoober »
https://forums.nicoclub.com/ubernoober-u14357.html
Sat Jun 19, 2004 9:32 am
With increased boost comes increased exaust temperatures. If the factory exaust valve becomes overheated, it could re-temper the stem causing the head to pop-off and cause catastrophic damage. Be thankful that Nissan does not use two-piece valves (stem with the head welded on) like my old Fords. These things will simply fly off by using heavier springs and pushing the RPM out a few hundred. Nasty.
Ok, that being said, I would look into the material and design used on the KA and see if it was the same for the SR. I bet it is, in which case, the SR is already boosted and is a known factor. It would confirm that the factory valves are perfectly fine as long as you keep an eye on your pyrometer. If you were made of money, you could always go stainless or sodium-filled, but I doubt it is worth the cost. I will look into it though, since I am in the planning stages of my own KA-T with the same engine specs and boost as you.
BTW, "burning" a valve is kinda a misnomer. An exaust valve dissipates heat by contact with its seat, and a very small amount by the cooling action of the intake charge. As the exaust temps rise, the valve head or stem can start to warp as it approaches design limits. When this happens, incomplete contact with the seat occurs making it harder for the valve to cool off. This continues the climb in temp of the valve until either the rather common, permanent warpage (leakdown failure due to incomplete sealing) or the far less common, catastrophic physical failure.
