schanne »
https://forums.nicoclub.com/schanne-u47706.html
Wed Dec 26, 2007 9:32 am
My car has been running like crap for a while and I'm soo lost right now it really sux! Here's the history of what my motor has been through and mods.
Motor was rebuilt(shot bearings) and installed by a half ***ed mechanic. Z32 Maf, AFC-Neo, Fmic, cometic HG, uncir. BOV, pully's, walbro 255....
Car was not tuned and ran, but never pulled. Turbo would spool perfectly and sounded great just no go!! The car did run rich for about 7k miles because of no tune. When I had the oil changed one time the oil smelled like gas and was a lil liquidy. I put Royal p in it now and can't really tell a difference. But now the problem is after cleaning the iacv valve it hasn't ran right since. We completely rewired the harness just beacause it needed it anyway. The ecu gives codes for Maf and Tps but I replaced the tps when I first got the car back and the maf was replace from z32 to sohc. We took out the afc as well and the car still doesn't run. So I did a compression test and 156 on all 3 cylinders but #4 would go from 170-160-165-156-170. I was told that is because of an exhaust valve being stuck. I know that I need to take the intake and iacv valve off and clean them out but what is the damn problem with this motor? What is my next step? And what is it most likely that the problem is?
All help is greatly apprieciated!!
