exhaust valve on y34 problem.
CAUG2
Car: 03 M45
Hi,
i noticed my exhaust valve is not working. i try to tighten it and no luck.
any idea how can i fix it?
Its located on one of the pipes before going in to the muffler.
thanks,
C
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
How do you know it's not working?
CAUG2
Car: 03 M45
i had my body flooring it while i looked and valve didnt move, it used to before, i did the say test.
i did it in park of course.
C
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Check the small unit in the trunk with a multimeter to make sure you have an RPM signal. If you have power and ground and the valve is mechanically free the actuator is probably the cause.
http://www.nicoclub.com/FSM/M/2003/ex.pdf
CAUG2
Car: 03 M45
Wow,
Thank you very much.
i will check it out on thursday with my mechanic.
Thanks again,
Caug
PS.
Would valve work, if car turned off?
