InsanityInc »
https://forums.nicoclub.com/insanityinc-u19073.html
Wed Jul 27, 2005 11:04 am
Actually, yes. If your code is the EGR system, it's probably that you don't have enough backpressure to normally actuate the EGR BPT (backpressure transducer). In order for it to work, you can bypass the BPT by just running the vac line straight to the EGR valve. As long as your canister control/EGR solenoid is working properly, bypassing the BPT won't cause any issues.
