Exhaust tip help
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
abnranger67
Car: 2008 Infinity QX56
Hi all, I have a 2008 QX56, and I want to change my exhaust tip from sticking out the side to coming out the tail end. I also want to put a dual-tip on it. Any ideas? I would love to know what some of you have done to modding your exhaust. That said, anyone replaced their entire exhaust system? The idea of cost. Thanks in advance.
Welcome aboard!
Since it's not a common vehicle to modify, I'd doubt if anyone has done that yet - but it sounds cool!
A couple thoughts: Since the Armada has a big hatch, the exhaust is likely routed to the side to keep soot from building up on the rear panels (and to keep fumes from sucking in around the hatch seal).
BUT, if I were doing it, I'd find a local muffler shop and ask them about fabricating something on the lift (that's the easiest way if there's not already an aftermarket exhaust). Might be cheaper than you think.
abnranger67
Hey thank for the tip and information. After what you've explained, I'll keep it out the side.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
