up pipe?hpfreak wrote:ne suggestions on exhaust systems preferences??? and up & down pipes?
second that, i have basically the same deal, its like an ochestra is following me aroundgomer23 wrote:I have a custom 3" exhaust with Hooker Straight through muffler... I have had multiple comments on the sound of it. Nice deep sound to it.
thanks, I think...nizmo zilvia wrote:Your car sounds evil. Must be a straight 6.
The best thing to do for ground clearance is to put a jack on the catback around the sway area... then build the downpipe toward the bolting area and add bends accordingly. This is of course if you are building it yourself, and if you have someone build it for you... I would suggest you ask for that as it aids in the priceless ground clearance of a low car (like mine).tecnic1 wrote:depends on mounts and chassis, really.
I have the tophat mounts/s14 and there was no option. I had to get my o2 housing/downpipe fabbed up. The stock never would have fit, and the ebay housing only fit after I cut it in half.
I think I got a little more ground clearance then most though, so it's not really a bad thing.
I know your not talking to me but Im sure I can help if you care. I do believe his RB is a 20 iirc. The RB20/25s are interchangeable. As for McKinneys DP, waste of money because all it is, is a 3" pipe which you could get from ebay for $150 or make your own. Nothing special about that.l0nestar wrote:rbsileighty,
I like the idea, is that motor in the pics a RB20? Is there a difference between the 20 and 25 dp's? Is it really worth the $240 that McKinney is asking for a DP? My cat-back exhaust is 3", so I assume I should get / fab a 3" DP correct? Thanks for the tip about pre-heating as well!
I think my mounts created more of a problem clearance wise.. I had issues people don't have with crossmember swaps. My driveshaft was too long, I was hitting the firewall on both sides (not normal on a 20) and the aforementioned required custom 02 housing/downpipe.l0nestar wrote:tecnic1,
I'm doing an RB25DET S1 into a S-13 (93- with DE) and was planning on using the X-Member / mounts from the R33 Skyline GTS-T clip. From what I remember, the motor stays about an inch higher and forward in the bay, as opposed to using a set of TopHat or McKinney mounts. If I am going to run into serious clearance issues I will order a set of mounts, but I would rather spend the $ on something else (misc parts) if I could. (Although, I could just fab up a set of mounts myself...
That is a RB20... but the turbo is off of a 25 they are more or less the same anywayl0nestar wrote:rbsileighty,
