Will like to add:Clean the threads on both sides using brake cleanerLoctite (blue) will NOT hold to that temps, Use Red Loctite and do NOT overtight the bolt.nissanfanatic wrote:no........don't just put it back in.....
take another one of the exhasut manifold nuts and put it on top of the existing nut. Put some loctite on the end that goes into the head. Use the two nuts on top of each other to make a locknut configuration using two 14mm wrenches. Try to loosen one while tightening the other. GEt them pretty tight. then you should be able to use a 14mm socket and put that stud all the way back in. Let it sit for a lil while so the loctite hardens. then use the two 14mm wrenches to undo the locknut configuration and take the nuts off.
hell no man!! Its all about the PB BLASTER!! haha, that stuff is the bomb!nissanfanatic wrote:Kano-kroil works the best.
If the bolt breaks then you gone too far. The nut isn't stuck on there.Just the stud came loose.I could spray some pb blaster on the nut and it would come off. So the question really is how to install a stud properly4felix20 wrote:torque specs? i'm not sure..
