Agreed - but from what I'm understanding, part of the stud is still in the head? You need to get that out first. I just removed two broken studs from an RB25 head that were broken off below the surface. I used a MIG to build a weld up on the stud until it cleared the head, then welded a washer to that, and a nut to the washer. That allowed me to use a ratchet to remove the broken bit of the stud.240z4u wrote:I'd use time-serts in this application. They won't back out like helicoils will.
You may be correct upon reading that a 2nd time, it does seem that he's got broken off studs. I thought that he meant that the threads were pulled out of the head.huafist wrote:Agreed - but from what I'm understanding, part of the stud is still in the head? You need to get that out first. I just removed two broken studs from an RB25 head that were broken off below the surface. I used a MIG to build a weld up on the stud until it cleared the head, then welded a washer to that, and a nut to the washer. That allowed me to use a ratchet to remove the broken bit of the stud.240z4u wrote:I'd use time-serts in this application. They won't back out like helicoils will.
I did a little bit of research on the time-serts kit and there not cheap. I believe the kit for M10x1.25 is around $400.00 bucks plus. Any other alternatives besides taking it to the machine shop. I'm capable of doing it in house240z4u wrote:I'd use time-serts in this application. They won't back out like helicoils will.
