I've come to the conclusion that it is probably some kind of body leak that is causing exhaust to be sucked in from the back of the car due to a vacuum created by having the windows down. Google tends to agree with me.
My question is, do you guys know is there a common leak area I should be checking? I see the old Z's had problems with the hatch seals, and tail light seals that would cause this. Is this a problem with this car too?
Thought I would check to see if you all had any ideas. I'm planning on giving the method described in this link a try and will report back what I find.
http://www.classiczcars.com/forums/exha ... olved.html
