Checkered-Member »
https://forums.nicoclub.com/checkered-member-u10193.html
Sat Jul 02, 2005 2:26 pm
First lets understand how the turbine works, there are many forces at work, one of them is the fact that inside the turbo manifold pressure is higher then outside, so pressurized air (exhaust) wants to go down its concentration gradient which lies outside of the turbine, this force drives the turbine.
So lets say we had no down pipe, the turbine will work at maximum efficiency, however that’s impractical, the more restriction we put on the turbine the less efficient it will be, so the down pipe needs to be as big as possible, so there is a nice difference in pressure between the inside and outside of the manifold.
The rest however, for street use, meaning that at idle it doesn’t sound like a 420 V8 I would stick to 2.5 so it’s not ultra loud
On a side note: there is a turbo kit out for a 2001-2005 Honda civic, the guy who made it, made a special downpipe for customers in California, there is a cat in the down pipe, guess how much power the turbo kit makes? 30 hp over stock @8 psi, you can get that with Bolt-ons…lol
