Exhaust setup for SR20DET VVL
slc240sxse
Car: 96' 240sx SE
Hi guys.
I have a quick question, that should be answered easily enough.
Just picked up a SR20DET VVL S14 Blacktop. It comes with the downpipe from japan, but from what I understand, I will not be able to use it.
What will i need exactly? I see plenty of downpipes on ebay, but none of them are setup for an O2 Sensor. There are some sets that are around 500 bucks, but as I am not familiar with the brand names.
As I have to do the entire thing from the turbo back, what would you guys suggest?
Thanks again.
slc240sxse
Car: 96' 240sx SE
Someone has to know.. jeez..
slc240sxse
Car: 96' 240sx SE
Ok.. so after looking at the FSM.. it looks like this one would work. Car is a 96.
http://cgi.ebay.com/ebaymotors...=WDVW
So, what do you guys think? Look good?
Modified by slc240sxse at 1:08 PM 7/12/2005
S13240
I think the reason why no one has said anything is because you didn't mention what car is this engine going into? I'm assuming since you're looking at the s14 exhaust system you're dropping an s14 sr20 into an s14 chassis which the stock dp and your stock s14 exhaust will bolt on to no problem.
slc240sxse
Car: 96' 240sx SE
Aw geez. Sorry abou that. Yes, the vehicle is a 96' s14.
So the stock exhaust will work? Probably just work a cat back then i assume.
Will having the Cat on there still cause any problems with the s14 that you know of.. anyone?
Thx
Rosco
Car: 91' SR'ed Hatch
On the turbo extension there is a spot for your O2 sensor to be placed:http://www.srparts.com/turboupgrades.htmlThe downpipe has nothing to do with the o2 sensor...
S13240
You can leave the whole exhaust system stock and will not ruin anything. It's just another engine, engines don't require anything more or less than others.
nismostate
Car: all sorts of motorsports
with the stock dp and exhaust, you wont be able spool as quick. otherwise, everything should be fine. use the stockers if you need to save some money
