exhaust's sound level
nomuken
What is the proper way to measure the sound level of an exhaust? At what distance from the exhaust tip do I need to hold the meter? Do I measure the sound when the engine is idle or at some higher RPM?
Thanx,nomuken.
P.S. If anyone knows how loud their exhaust is, please post.
Anand
Car: 95 Nissan 240SX
you hold it 3' from the tips parallel to the tip...
you measure it between 4k and 4.5k RPMS
that will tell you the dbA of your exhaust.... it's usually mesuared @ 4200 RPM... but it varries between the figures I told you.
lessthanjakejohn
Use an SPL meter from radio shack... I think they are 35-45 bucks
nomuken
got the RadioShack meter, it's pretty fun to play with :D
nomuken
Black240 wrote:you hold it 3' from the tips parallel to the tip...
thanks, i tested mine and got 97dB! that's pretty loud. what's considered normal/legal?
dr!ft
Car: 1988 Isuzu Trooper II, wish it was a 240...
I think it's 95dbA for California. Could be wrong though...
Anand
dr!ft wrote:I think it's 95dbA for California. Could be wrong though...
absolutely correct!
it is 95dbA... if you tested it yourself... then you should add a dbA or so since you can be off...
If you have to get it tested for a ticket.. I sugget get a silencer.. put it on.. go get it tested... pass it... get a sticker... turn the ticket in and then take the silencer off...
keep the records of you passing in the glove box so next time you get pulled over.. you can just show it to the cop saying it passes the law!!!!
that's exactly what I did and going to do...
Bunta240
I need to test mine too. I know for sure it would fail horribly. I hate ricey previous owners...
lessthanjakejohn
Whats the dbA stand for? (the A in db)
Get240DiZzY
Car: Rallying. My 240. Not at the same time though.
DeciBle Amplitude
Just a guess, but it makes sense. :oface
dr!ft
Black240 wrote:absolutely correct!
Score one for the dr!ft man! :ylsuper
evilsil
Car: 95 s14w/ s15 front & Rb26det (single turbo upgrade) W/ Tomei built head
use this. you can get it @ autozone. it should help[img]http://www.kimcheeracing.com/Exhaust-Bearing.gif]/img]
evilsil
sorry here
