Exhaust question
Lunzee
Car: 1990 300zx na 2 seater
Here'll the previous owner of my z decided to take the cats out and straight pipe the car, the car is loud but I can deal with it, but first I need to pass California smog laws, my question to you, is if I have a couple stripped cars laying around can I just cut two cats off and weld them on my exhaust and pass smog for a day?
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
I never had to deal with having my car smogged in cali but I would think you should be able to as long as the cats bring the CO lvl's down to withen limit. Visually it shouldn't matter whether they were welded in or not as long as they are there.
Z31toZ32
Car: 1999 Infinity QX4
i would try this first before you do all that work:
http://www.300zx-twinturbo.com/tech/co/co.html
NolimitZ32
Lunzee, where are you? different states have different laws and regulations, in TX that would be fine as long as the emissions levels were brought down to acceptable/passable. in Cali AFAIK the cats must be CARB certified for the specific vehicle they are on otherwise you do not pass go and do not collect $200.
300ZXttZMAN
Yea Lunzee post your location please. :bigthumb:
Lunzee
I am acctually in California about 10 minutes from willow springs in a little town called tehachapi
300ZXttZMAN
Ok just edited your profile to say you live in Willow springs, California.
Thanks for your cooperation. :bigthumb:
NolimitZ32
Lunzee, I'm not 100% on Cali emissions laws but I am pretty sure you will need stock 300zx cats before you can pass emissions. Check with your local emissions authority (dps/dmv/CARB) not sure who handles it in your state.
Lunzee
Well I know California emissions laws require stock cats but the smog shops here don't check visuals just if any cats will lower the emissions enough.
And thank you ttman I appreciate it
300ZXttZMAN
Lunzee wrote:Well I know California emissions laws require stock cats but the smog shops here don't check visuals just if any cats will lower the emissions enough.
No problem man its good to have you on nico club :bigthumb:
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
High flow cats can pass sniffer tests if fully warmed up, but may fail visual at an anal-retentive station.
No cats will fail a sniffer test.
