SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Tue Jul 07, 2009 12:36 pm
I have seen several coupes with HFC that were on long enough to rust (I really don't know how long) (People tend to get awful quite when you mention HFCs).
The ones that have made their way into my bay through severe driveability or persistent check engine lights and are usually beyond repair. The life span of these parts is not nearly as long as OE and people often overlook the early warning signs. The signs seem to be rattling niose when under load. Very similar to that video. This is the material separating from the housing. If you are lucky the material breaks in a large chunk and your engine will only ingest catalyst dust.
However if you have something like a brief ignition missfire the cats can detonate in seconds. Raw fuel and heat will cause the cat to break up into much smaller pieces. This is where the real bad stuff happens. I had one that sucked in a small piece of honeycomb shrapnel into the #5 cylinder and destroyed the plugs and made a complete mess out of the cylinder.
You would really be better off with test pipes. Although I am not a huge fan of the violating federal emissions rules bla bla bla, mostly I dislike the noise, smell, and poor fuel economy that usually accompanies this type of modification. The G is not a car for this, Honda maybe.
I don't have the pictures anymore of the engine that I have seen, although the next one I get I will be sure to give you all some more pictures.
