Exhaust question
Camel
Car: That would be obvious....
I am running an Apexi N1 single catback with resonator(75-85mm piping with 110mm tip) on an NA setup. Stock header and cat/downpipe/fakecat on a 98 ka. After i have run it hard for 20 to 30 minutes it tends to sound like it is popping inside the pipe. Not really a backfire but a resonant popping. It seems like I don't have enough backpressure for an NA setup. I am running with the silencer, that definately helps quiet it down a bit.
Here's what I was wondering, could I have a muffler shop replace the fake cat with another resonator to calm it dowm a little and add a little backpressure back into the system? I don't plan to turbo for a while, but i got a good deal on the catback system so I went ahead and put it on.
I have searched and not found any answers that fit my specific situation.
Thanks for any good advice...
C
Camel
Anyone want to comment on this before it rolls off the board? I would appreciate it greatly.
Structure240sx
mine always did that before and after turbo. before when i had mineke 2.25" custom and my gp sports spec d. its jsut natural i think technoman might have said . the stock exhuast is so restricting and has dampners that keep u from hearing those lil pops whatever they are
Camel
Thanks Structure. That makes me feel better about my purchase and install. I thought that I may have gotten too large of piping and it was causing problems. Is this exhaust too big for an NA car?
Structure240sx
not really you'll just lose some low end power but your top end will be a lil better than a smaller exhuast. its jsut more suited for turbo.
lbrowne
I'm just replacing my cat with a new one, removing the resonator, and replacing the old and tired muffler.
Keeping the stock 2 inch piping. I have more exhaust coming out around my cat than I do out my muffler :D
